407.987.5
Marcy57
Constant carrier with (chirping sound?) every 10 seconds kinda weak hr
also some other observations this morning:
413.870 Paging every 60/90 seconds (almost sounds like POCSAG?) also 411.012.5 same
408.212.5 constant data
409.012.5 same
406.500 same
406.187.5 voice in the clear...not sure who??
73,s Marcy
dave3825
Suffolk County NY
With her being in Yaphank on Eastern LI, 408.2125 could also be the Federal Correctional Institution Danbury. She is about 55 miles LOS to Brooklyn and 45 to Danbury
Marcy57
With him being in Yaphank on Eastern LI, 408.2125 could also be the Federal Correctional Institution Danbury. He is about 55 miles LOS to Brooklyn and 45 to Danbury
np...thanks...Marcy
ecps92
Taxachusetts
hence the comments about needing NAC, SysID, Connect Tones other voice channels. - which most common day scanners would present in the display
Marcy57
the 406.187.5 was in the clear ...not too much in that
range 405-419 in the clear anymore so I was kinda
surprised to hear it! transmissions are brief so not easy.
Marcy
ecps92
Taxachusetts
CLEAR Analog or CLEAR P25 ?
if P25 your display would likely show a NAC
Marcy
ecps92
Taxachusetts
Well that rules out the prisons, as they run P25 Voice.
Going to now go with an image. Also what radio are you using ?
in some of your past postings you have two decimal points when listing frequencies, which makes me think, this is not a scanner
clear analog
k2hz
Rochester, NY
409.012.5 same
406.500 same
73,s Marcy
My experience in tuning around that frequency range with my R7000 is a lot of weak constant or pulsing carriers with beeps, chirps or digital sounds. All appear to be incidental radiation from my own or neighbors computers and electronic devices. The fact that I am using a discone in the attic makes me susceptible to "in house" generated interference. But, what you listed may be legitimate signals.
I use DSD+ and some other programs with the discriminator output from my R7000 to analyze digital signals and kgtone for PL/DPL.
