410.075 (a)
Marcy57
Long Island...NY
Anybody know what this is? it,s like constant data bursts vy good cpy here
it has a ACARS sound to it almost (lol) although I know it is not that just
sounds like it....just curious...vy strong hr so can,t be too far from Suffolk
county I presume??...tks 73,s Marcy
dave3825
Suffolk County NY
I only receive it here in Islip Terrace if I lower squelch all the way. It could be coming from across the sound in Connecticut. Maybe @ecps92 might know or @pro106import could key it in since he is in CT.
Marcy57
Long Island...NY
ok ...tks to both, I knew it fell in the Federal band allocation area just sounded so much
like ACARS! too me...73,s Marcy
dave3825
Suffolk County NY
It's one of several commonly used frequencies nationwide that is used at many airports to send data from the weather instruments out on the airfield back to the building.
And yet there's only 7 locations that were submitted to the database.
Maybe someone close to it could make a submission? Its strong in Yaphank NY and very weak in Islip Terrace NY.
410.07500 Bowling Green/Warren County NWS/ASOS TelemetryAircraft Operations
KBWG Operations
Bowling Green Warren County Airport (KBWG)
Warren
KY
410.07500 Automated Surface Observing System (ASOS) DataFederal
Spirit of St. Louis Airport
(Chesterfield)
Airports - Other
St. Louis
MO
410.07500 National Weather Service (NWS) - Automated Surface Observing System (ASOS) DataFederal
Dallas Love Field (DAL)
Dallas
TX
410.07500 National Weather Service - Automated Surface Observing System (ASOS) DataFederal
Hobby Airport (HOU)
Hobby Airport (HOU)
Harris
TX
Bush Intercontinental
Airport/Houston (IAH)
Bush Intercontinental Airport/Houston (IAH)
Harris
TX
410.07500 Automated Surface Observing System TelemetryNational Weather Service
Federal
NuecesTX
410.07500 Federal Aviation Administration - Data (Automated Surface Observing System?)Federal
Reagan Washington National
Airport (DCA)
Reagan Washington National Airport (DCA)
Arlington
VA
ecps92
Taxachusetts
You must be right near an airport ? which one
That freq is assigned to the NWS at airports [altho many folks submit it as FAA]
it is the NWS ASOS system of Telemetry.
Example of the NTIA info
U *** M410.075000 C 890217 M NWS FX 16K00F1D W1.00000 S361 J1439613 890516 180829
I8925502
J0870939
J0191206
I9756185
OK TULSA IAP 361154N0955315W 06GDIPOLEARRY00193H0007T ND 1
OK TULSA IAP I,NTIA-U 361154N0955315W
A CONTROL UNIT, ACU, TRANSMITS TO 1 OR MORE DATA COLLECTION PLATFORMS *RAD,0002,R
DCP, LOCATED AROUND THE AIRPORT. THESE SENSORS MEASURE VARIOUS WEATHER *NRM,00010,NET
CONDITIONS SUCH AS BUT NOT LIIMITED TO VISIBILITY, AMBIENT TEMPERATURE, *EQS,LMS
WIND DIRECTION AND SPEED. THE DCP THEN TRANSMIT THIS DATA BACK TO THE *MFI,WEATHER
ACU. THE SYSTEM UTILIZES THE ASSIGNED FREQUENCY IN SIMPLEX OPERATION. *AGN,SRMO180073
*IFI,ASOS
*AGN,KTUL WSFO TUL
*POC,DAVID JERKINS,8179787777,180802
IC-R20
LoBand Nation
So what’s the list of the other 6?
nd5y
Wichita Falls, TX
The only other federal frequencies that I know of that I have actually heard something on are 406.25 and 410.95. There may be other bands used depending on what equipment a particular airport has and when it was installed.
Some airports don't use federal frequencies like this one where I live.
Marcy57
Long Island...NY
preamp..helps here alot it,s like S6/7 squelch off
unless it,s from Riverhead but doub it??...Marcy
dave3825
Suffolk County NY
You have,
Gabreski Airport in West Hampton
Brookhaven Calabro Airport in Shirley
Calverton Executive Airpark in Calverton
Do you have a handheld or mobile scanner?
ecps92
Taxachusetts
There have become more of those at airports as NTIA moved some to splinter 12.5 khz channels, and then there is also FAA users with WX telemetry [Windsheer etc]
Most of the newer Digital scanners don't attack it fast enough for folks to notice it, generally I rely on my older Analogs to find these.
ecps92
Taxachusetts
I think, I've gotten it at both airports
2010 for Groton/New London
2014 for Tweed
Only NTIA indication for Statford, but have found it in CT AT
Bradley from 2010
Brainard from 2009
I am right in between Tweed New Haven and Sikorsky Bridgeport - Stratford Airport.
I get the data signal full scale, but take your pick on which one it may be.
Nothing useful to hear anyway, unless you can decode the data.
