422.5500 DT3
mciupa
Canadian DB Admin
Moderator
I'm here a lot
While I was searching 420 to 424 MHz, I came upon 422.550 Colour Code 0 and DT3. My first thought was that it could be Point to Point in King City. When I put that site on hold, it was showing up as Connect Plus and not DMR TIII. It has a booming signal into Toronto. Any ideas who this is?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
As you say, likely Point to Point as I am seeing Network 1 Site 2. Site 2 matches King City on the Connect system.
002 (2)King CityYork422.9875 422.550c422.350
I'm living in the dark ages with DSD+ 1.01 :confused: so pickin's are slim regarding neighbours, etc.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
@mciupa I am using that version of DSD+ as well. :( I really should just pony up the money and buy it. The way my luck works I will and the project will be discontinued.
Fast Lane was updated recently and there are many subscribers. I don't think it will disappear.
Let's look at a lifetime FL subscription (about $35 Canadian) and a decent SDR dongle around the same price. Compare that to the price of a higher end digital scanner. You could buy like twenty dongles and the DSD Plus Fast Lane. Do we really need the expensive hardware of a scanner anymore?
gary123
DSD Plus Fast Lane is worth the investment. It can be used to display more than just active TG's or track trunking. The one time lifetime payment is super reasonable and as it has been mentioned it shows interest in the product and motivates the writers to continue to update and upgrade it.
Having said that, I would be open to an 'advanced setting' that will display more of the CC data than is currently shown. NO, not encryption support, just a single or default setting that will show all CC information. Such as SID, NAC (Color Code on DMR), Voice channels (slot on TDMA and DMR), TG's, neighbors and band plan. DSD does display many of these parameters but having a single setting to just monitor CC data would be super convenient. Pro96com displays a lot of this information such as the bandplan but sadly it does not support the newer Uniden scanners or a direct discriminator tap connection (DSD Plus Fast Lane does).
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Well, I finally got off my arse and purchased Fast Lane.
I was hesitant to upgrade to Fast Lane because of Pay Pal and its data mining reputation. But you know what, I put that aside made a pay Pal account. Sent the funds to dsdplusfastlane at 4:20 pm, received my software at 4:29 pm. After reading the Notes.txt, I started the program and was listening to calls and reading data like crazy.
gary123
If we have a channel number for the site or a frequency for one of the neighbors I can use that to make a reference app for the other CC frequencies. So far it looks like the base frequency may be 420 or 422.
