457.73125 - DMR Mystery North of Seattle (Kenmore Air on DMR?)
devicelab
Radio N.E.R.D
WA (USA)
So it looks like there's an active voice channel on Site R93-8. Its CH ID is 8 but no idea of the frequency. It's NOT the remaining channel from the old site -- it's still being used for Site L2029-8. It's an odd CH ID so will have to hunt around for it.
The control channel supports one voice channel, but the whale watcher boats are out in full force this morning. They're causing the 2nd frequency to come in to play.
BC_Scan
Vancouver BC
2029 ID has been coming from BC since inception (at least to me) freqs from 410 mhz to 422 mhz
even the vhf assignments for RCC in BC not linked to the uhf side show 2029
bcradio
Victoria BC
Some very limited reception of site 7 on 452.625 . It's barely readable here, but this is the data comes through on DSDplus:
Sync:+NXDN48 TB CCDATA ERR17 SITE_INFO Category=Regional System=93 Site=7 MultiSite LocnReg GrpReg CompCC Voice Data ShortData Status&RemCtl IPNet Version=1 Neighbors=0 CC=398
bcradio
Victoria BC
Further to site 7 on R93, had some activity on talkgroup 243 today which opened up two new voice channels. Will try to nail down their frequencies.
243 451.375
301 ?
358 ?
398 452.625
I suspect 301 = 452.125 and 358 = 452.35 just going by the FCC licenses, but I cannot confirm.
RID 2261 [N900KA] affiliated with this site as it crossed the strait towards Victoria.
bcradio
Victoria BC
Question for you, though....
In the FCC database that RR has, it shows two entries:
Different emission types, yes.. But I can get a better decode using 451.371875 than I can using 451.375. But according to the lat/long, these are coming from the same place.
Can anyone enlighten me as to what is the actual frequency to monitor? Or does it depend? Like is one directional one way, the other the other?
Or is it just a database quirk?
Or a problem with my receiver?
BC_Scan
Vancouver BC
so in this instance FCC says digital to Wiz, you build out as you see fit, they as we know use NXDN 6.25 , so .375 is an actual other freq to carry traffic on .371875 could be Control channel
I have logged a DMR system Wiz uses on other fx , so from my perspective they have a pool they take from based on license then put into service as they need , I believe SDR is invaluable in showing what is in use on any given moment , as I read on the forums here every day something new different then previously observed !
devicelab
Radio N.E.R.D
WA (USA)
The problem is most scanners do not have filters for anything less than 12.5khz but I believe the Uniden SDS series actually do filter 6.25 khz bandwidths. I believe the Uniden 325/996 might as well but I'm not positive.
Kenwood LMR has always used different frequencies -- I'm guessing so their digital doesn't conflict with DMR running at its typical 6.25khz channelization.
I always use the receiving frequency. In rural areas it may not be an issue but in King County there's not much space left. You'll get multiple digital signals if you run too large of a bandwidth.
devicelab
Radio N.E.R.D
WA (USA)
Confirmed Kenmore Air on TG 185.
RID == 2240 [LK WASH BASE]
RID == 2241 [LK UNION] (DISPATCH)
RID == 2246 [N903DP]
RID == 2254 [N87KA]
RID == 2255 [N90422]
RID == 2257 (none)
RID == 2260 [N17598]
RID == 2261 [N900KA]
RID == 2269 [LK WASH BASE]
Updated list.
devicelab
Radio N.E.R.D
WA (USA)
Update: these control channels and the R93 network are no longer present -- at least in the King County area. Looks like the system has been deprecated.
MrCCTC
For Wiztronics System 93 Site 7 (Clallam) These are the LCN
452.125000331RAN 7
451.375000243RAN 7
452.325000358RAN 7
451.975000301RAN 7
452.625000398RAN 7
devicelab
Radio N.E.R.D
WA (USA)
The OP was on the input frequency to a Tiger Mtn site voice channel. I just submitted an update which will reflect the confirmed Tiger Mtn information which has since changed. It's still operating as R93 but AFAICT, it's the only one.
MrCCTC
There are sites for this Wiztronics system 93 spread all around the northwest. They have just recently changed all of their sites from their System 2023 to this new system (switching some frequencies and LCN in the process) You are right that Tiger Mtn is the only site in King County though.
devicelab
Radio N.E.R.D
WA (USA)
There are sites for this Wiztronics R93 spread all around the northwest. They have just recently changed to this new system (switching some frequencies and LCN in the process)
Okay, so it looks like the R93 mapping is still progressing. I finally found the R93-8 (Tiger Mtn) control channel tonight, but I need to verify the voice channels once more before submitting them to the DB. Most of the sites have changed over but some frequencies haven't shifted completely. e.g. Site 10 still has a L2029 control and also a R93 control.
devicelab
Radio N.E.R.D
WA (USA)
R93 site has been uploaded to DB.
As you can see, there are missing frequencies with new CH IDs. I have the IDs but cannot confirm the frequency from my location. If anyone else can then that would be great. Hint: the frequency hasn't change, just the CH ID.
Apparently, this is still a work-in-progress so expect changes over time.
dachs494
I have R93-1 showing up on 412.684375 (CH77). Is anyone else seeing similar R93 activity on that band/frequency? It has been there for a couple of weeks at least. Very weak signal. I'm not finding any CCs for sites that have not already been identified from 450-470.
EDIT: Looks like it's the Canadian side of the system, which is likely to be the Mount Seymour site.
