463.2875 MHz DMR Philadelphia, SE PA Area
rrbum
Whiskey
As I type current rest channel.
463.28750
Color Code 15
Channel 3/4
Site 3 Neighbors 1/2/4
Wild how the UHF freqs bounce in and out, I have not seen CC15 from here.
I do receive several transmitters. Two are DMR with CCs of 11 and 3, as well as a weak morse phone number of a communications company out of Trenton NJ. I would like it if any Trenton NJ area radioheads could respond if you can copy the MPS communications morse on 463.2875 and identify usage of same.
I kinda don't think the security outfit on CC3 is gonna be CHOP. Like OP said it doesnt add up.
rgchristy
Delco, PA
I look at it this way. I'm not going anywhere (hopefully), and eventually they will mention something that will ID the location. It amounts to about 10 recordings a day to listen to and I pretty much know if it's around 07:15, 15:15 or 23:15, that it will be a radio check.
I posted it, looking to see if someone has run across it before.
We'll figure it out. ...the impossible just takes a little longer...
rgchristy
Delco, PA
We're getting closer...
Now, if she only said which authorities she was going to call...
Oh well, patience Grasshopper...
Please remove .zip to listen.
  • 20250316-172502.AU.ZIP
  • 20250316-172525.AU.ZIP
  • 20250316-172636.AU.ZIP
  • 20250316-172710.AU.ZIP
  • 20250316-172928.AU.ZIP
  • 20250316-173000.AU.ZIP
