5023 "P" button programming
VA7-GHE
Delta, BC
Good day
On a IC-5023H
Anyone know if it's possible, and if so how, to program one of the "P" buttons to select a specific memory channel?
I would like to be able to select say, P4, so that it would go to a specific frequency. I can't see how that can be done going through the options in the software.
Thank you
kny2xb
North Clearwater, FL
I don't have your model radio, but I have the software for it, it's also for the F3021/4021 h-t's, I have the F4021S
Program the frequency that you want fast access to in Memory 1, 2, 3, or 4
Go to Common, then Key & Display, then the particular P button you wish to use [say P3], in the drop down functions you have the choices of MR-CH1, MR-CH-2, MR-CH3, & MR-CH4
[On my h-t's I use P0 for High/Low power output, I know it's a zero, not an O, but it's close enough for me]
I hope this helps
73
P
VA7-GHE
Delta, BC
Thanks Greg
I did find that, but what I cant figure out is how or where to assign Frequencies to the 4 locations (MR-CH1 etc)
I ended just assigning the frequency as Priority A and then assigning Priority A to the P button
Still like to know how to assign frequencies to the MR locations. Be great if you could tell me that.
Thank you
Gord
kny2xb
Thanks Greg
Thank you
Gord
Good Morning Gord;
Are you using zones? That probably will make a difference in setting up.
I'll have to play with the software & experiment a little, as I haven't used the P buttons for channel access
Greg
Worst scenario is to contact Icom Canada support, they're actually in Delta, how lucky can you get LOL
VA7-GHE
Delta, BC
Yes I am using ZONES.
LOL I have touched base with ICOM (actually only 10 minutes away) Very helpful and quick.
They told me I had to Program the frequency as a Priority (A or B) and then assign that to a P button. They were closed when I got around to it yesterday evening and posted here as an alternative.
I will send them a note this morning and ask as well.
VA7-GHE
Delta, BC
OK, FYI, Just chatted with ICOM.
Haven't had a chance to try yet but as far as I understand it, the MR-CHx channels are self assigned.
They are the first 4 channels stored in the list in whichever ZONE you are in.
If you change ZONES, the memory are then the first four in that ZONE. If you don't use ZONES they will simply be the first four in memory.
I'll give it a go later and see if I have it correct.
Gord
kny2xb
Gord
I kind of figured that was the way it would work, but I'm relatively new to using Icom
I use zones, but I don't use direct access
But with your input, I think I'll set up a direct access button or two & try it
73
