536 I can not download on channels from sentinl the scanner says nothing to scan .
longfeather1
Chester IL 62233
Yes it will not let me get that for it looks like it work but when i take the cable off and the scanner come back nothing to scan
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
the only way i can get channels in my scanner is use zip code
You need at least one favorites list programmed with at least one system or conventional object to be able to scan something other than the full database (zip code scan). Once said favorites list is added it then needs to be enabled to monitor: MENU > SET SCAN SELECTION > SELECT LISTS TO MONITOR > [select favorites list] : On
Thanks but it is still saying nothing to scan
If the above measure fails to resolve issue, go through the items from the wiki provided in post #4. Start at subsection entitled "For the HPx, x36HP and SDS Series"
