Anytone 578 Ham vs Part 90
N9JIG
Sheriff
Moderator
Far NW Valley
On my shopping list is an AT-D578UV to replace my Alinco DR-638 in the car. I currently have a TYT MD-9600 at home and an AnyTone AT-D868UV portable.
I want to be able to use it for Part 90/95 activities as well as 440 and 2M.
I am trying to figure out if it can be set up for Part 90 (150-175 and 450-470) and ham (144-148 and 430-450) at the same time without having to reset it from one to the other. I can do that now with my existing two DMR radios.
I have had conflicting reports on this in the past, so I want to see if someone here can advise for sure.
If not then I would likely get another MD9600 for the car.
prcguy
I have one and can't find a way to enable commercial freqs and still have FPP. If I tell the radio its for commercial freqs it looses 220 amateur band and FPP. I believe you can computer program commercial freqs and 2m/440 amateur together but I really like the ability to add stuff on the fly via FPP.
Update: I just fired up the software and when you choose US commercial model you can computer program any freq from 136-174 and 400-480MHz. You will loose 220 amateur band and FPP. I also remember something about loosing ham type DMR monitoring functions like single or dual slot.
I have had conflicting reports on this a
sallen07
Rochester, NY
I believe there are two different settings in play. The first is the "model" of the radio, which determines what frequencies it can transmit on. The second is the "Working Mode", which can either be Amateur or Professional.
It looks like the default for model allows 136-174 and 400-480, and that works just fine in "Amateur" mode.
alcahuete
Southern California
The only way to keep 220 in play and have the expanded range on the other bands is to use Mode 14. That should keep FPP available as well. Does that keep the Part 90 cert. in play? I have no idea.
prcguy
No mode 14 listed in my software. I'll look for a more current download and see if that has it.
Update: Downloaded the latest version 1.11 (from Connect Systems) and no mode 14 there either.
alcahuete
Southern California
I believe they either took it out of the new versions or made it harder to get to. I don't recall. Go here: AnyTone AT-D578UV mods and information
Go to Selecting operational bands
Been a while since I've done it, but you need to get into test mode, and may need the software on that page to do it.
prcguy
Found you have to enter the password 5*0# and that allows you to select mode 14 for tri band and full band 136-174 and 400-520MHz. Now the problem is it dumps all programming and you have to start from scratch. If I load my same codeplug in it reverts back to whatever mode the radio had when that codeplug was written. I believe there is a way to convert the freq files to CSV then export and import back while in mode 14. Will try that tomorrow.
alcahuete
Southern California
You can do the export/import like that and it should work, or you should be able to hex edit your codeplug. Easier to export/import most likely, if you aren't used to hex editing.
WB9YBM
Short answer: no (at least not legally). Here's why: radios used in non-ham communications have stricter testing/rules to follow than the ham community does (type accepted versus type approved--and these terms may have changed since I looked at this situation last), That's why commercial radios can (and have been) converted from commercial use to ham use, nut not the other way around (well, at least not legally...and not by anyone willing to admit to it...).
prcguy
A part 90 certified Anytone 578 is the exact same radio hardware as the amateur only version. They simply restrict front panel programming and a few features with a software command to give you an amateur version or commercial version.
N4KVE
PALM BEACH, FLORIDA
Short answer, no. It’s only part 90 w/o FPP, & 220. And part 95 is totally different again.
