5G / Radar altimeter fix deadline will be allowed to end
chrismol1
Yea here's what the NOTAMs has said for a while now if of interest what it looks like
ILS RWY 01 (SA CAT II), AMDT 11D ... PROCEDURE NA EXC FOR ACFT USING APPROVED ALTERNATIVE METHODS OF
COMPLIANCE DUE TO 5G C-BAND INTERFERENCE PLUS SEE AIRWORTHINESS
DIRECTIVES 2021-23-12, 2021-23-13. 06 OCT 09:01 2022 UNTIL 06 OCT 13:24 2024
AD AP RDO ALTIMETER UNREL. AUTOLAND, HUD TO TOUCHDOWN, ENHANCED FLT VISION SYSTEMS
TO TOUCHDOWN, HEL OPS REQUIRING RDO ALTIMETER DATA TO INCLUDE HOVER AUTOPILOT
MODES AND CAT A/B/PERFORMANCE CLASS TKOF AND LDG NOT AUTHORIZED EXC FOR ACFT
USING APPROVED ALTERNATIVE METHODS OF COMPLIANCE DUE TO 5G C-BAND INTERFERENCE
PLUS SEE AIRWORTHINESS DIRECTIVES 2021-23-12, 2021-23-13. 19 JAN 05:01 2022 UNTIL
19 JAN 05:01 2024
mikewazowski
Forums Manager
Oot and Aboot
A lot of modern cell sites use "antennas" that are actually the entire RF package built into a plastic radome. They run a LAN cable and power, or power over Ethernet, up the tower to the RF package. Saves the RF loss of having the RF amps on the ground and the antennas at the end of the coax.
A small cell or similar could possibly use POE.
The larger antennas with built in radios have a separate power line and use fiber for connectivity. While they save on any RF loss from jumpers, they tend to weigh a lot and are a bear to change. Most sites will use a remote radio solution with a short jumper to a regular antenna.
Last time we had a broken cell antenna at work, it was before remote radio units. It was 1-5/8" Heliax up from the ground.
The antennas were multiple elements, cross polarized +45º and -45º, multiple feeds for multiple bands/polarizations. They also had a small actuator that that allowed adjusting the antenna pattern up or down depending on the need.
I had some close up photos of it, but those were lost in a freak iPhone incident.
mikewazowski
Forums Manager
Oot and Aboot
Yup, those were the days. Scissor brackets at the top for mechanical downtilt which evolved to manually moved rods which eventually gave way to servo motors. Now we're into beamforming to single out individual subscribers.
MUTNAV
Sounds like a lot of organizations trying to make this work.
At the same time, there having the DOD CIO starting to work issues.
Joel
ctiller
120 miles is quite far. The radio altimeter is really only used below about 2500 feet or so which is only within about 10 miles of the airport. i'm guessing they reverted back for some other reason.
CapStar362
GA, USA!
No, 120 miles to Atlanta, also, 35 miles to Augusta Regional and 10 miles to Aiken Airport. We get lots of military flights, too. I forgot to add, 45 miles to Columbia, SC airport.
i used to live in Conyers and directly under where West bound traffic for the southern half ( Runway 27L ) would make their crosswind turn.
from my understanding, the 5G issue comes from RALT's having seriously OLD filters and the FAA not working with the FCC to get them to get just newer bandpass filters installed. Those older filters much looser in tolerances to EMI with C-Band 5G getting involved at about what..... 200 MHz apart, those older filters were not spec'ed for such tight tolerances back when most of these aircraft were built.
Now days, that can easily be mitigated with newer filters that would eliminate this issue, but the FAA wont play ball with the FCC and says its their problem and pilots cannot afford new RALT's. They dont need new RALT's, they just need new RF filter components.
But this why Federal Agencies hardly every work together.
CapStar362
GA, USA!
Update...
Joel
^ ^ ^ proving my point. Pothole Pete Buttgag needs to light a fire under the FAA. FCC has done MORE than enough to work on this, FAA has simply given the middle finger.
They refuse to work together to solve this, at the expense of the world and FUBAR'ing schedules.
BinaryMode
2600 dialtone blvd
I have to wonder about mountain tops with 5G and radio altimeters barfing when planes are trying to clear the summit.
That part of "radar altimeter" so to speak is not. The PFD uses a database to display the elevations around the plane. It's like a Sandel TAWS (Terrain Alert Warning System) As opposed to the radar altimeter called a GPWS (Ground Proximity Warning System) Here's the gauge mostly used in helicopters. ST3400
Not too bad of a price, eh? LOL
MUTNAV
They say it's a supply chain issue...
Joel
BinaryMode
2600 dialtone blvd
FCC looks to be on a path to maybe fix the root cause: poor receiver design.
MUTNAV
It's great that you found that article , it's sounds like a good step forward for everything.
I think I read it differently though, I read that they want to change how all radios are going to be future proofed, since the spectrum use can change so quickly.
Joel
Will be interesting to see how far this spreads. I could/should make its way down to LMR radio. If it does, the CCR's are going to need to clean up their acts. The $14.00 radios might cost $20 after this….
RFI-EMI-GUY
Joel
RX Filtering is no mystery to anyone in the industry. However there are degrees of filtering, bandwidths, shape factors, INSERTION LOSS!, and the FCC, being a bunch of lawyers, not engineers has made a lot of harebrained regulatory changes (Should we start with NEXTEL? Or maybe Lightsquared?) without considering the incumbent technology. So it is easy to say, "its those terrible receivers", when in fact it was terrible decision making that created the immediate crisis. What the newcomers like to do is feign innocence and hope the incumbents will pay for their misdeeds. You can bet that emails were pouring into FCC HQ from retired FCC engineers when each of these dumb ideas were tabled.
New Motorola SCR-3000A P25 "Future Proofed" Filtering Package.
RFI-EMI-GUY
Whenever someone asks about one of those radios I point out they were never tested to TIA-603D. If I had spare time I would love to build a receiver test lab to pummel those receivers with real world signals. As it is my time is limited and I will be happy with using a sledgehammer.
RFI-EMI-GUY
Money well spent. I got a lesson about the predictive nature of that from the Mentour Pilot YT. I will be sure to ask the crew if they have one when I book my next flight.
MUTNAV
I was hoping more for something along the lines of ensuring that spectrum for (lets say VHF air ) doesn't have a new service adjacent to it that allows 40 Kw of EIRP, Even if the new service has out of band emissions down by 50 Db, it would still cause interference.
Joel
RFI-EMI-GUY
Joel
That would require FCC lawyers to admit that it isn't entirely the fault of the receiver. The FCC idiots auctioning off spectrum need to consult independent RF engineers in each and every case.
