668 - Delete only one playlist?
ohgaryoh
Is there a way to remove one specific playlist from the scanner locally?
Thanks!
marksmith
Anne Arundel County, MD
Delete or not select for scanning?
What do you mean by "locally"?
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
ohgaryoh
Delete the contents of for example "Playlist 008". Locally meaning directly from the scanner itself.
marksmith
I only know how to do it in the software. But I presume you could go to the display objects, go to playlist 008, and scroll through deleting each object, then going to the playlist and edit the name out.
Probably a lot easier in the software.
ohgaryoh
Ok thanks. Was afraid that's the only way.
