780 help needed
ProScan
Software Provider
Ontario, Calif.
KE0HIN, Does the scanner display show RMT indicating it is in remote mode?
Ubbe
Stockholm, Sweden
its a windows 10 PC I'm usinf a usb to serial cable ive matched speeds so on its a program I loved like 25 years ago ? just trying to update two 780's programs
There have been updates to Win10 that disables certain usb-serial chips, some sort of fake China chip. But I guess if the adapter cable can be seen in the hardware control panel and using a com port number then it should be ok. Some older programs, perhaps including Andrews, doesn't like a com port with higher numbers, force it between 1-4.
/Ubbe
KE0HIN
Berthoud Colorado
yes you press E for 3 seconds and it turns on RMT my thought is the cheep 3 dollar blue cable from amazon is fubar
KE0HIN
Berthoud Colorado
sadly my "pro scan 30-day trial" (cookie) got used up years ago otherwise I'd try that but still would have the cable issue, I always loved Andy's program but I'm a spread sheet junkie with frequency lists.
Thanks for all the help guys Ill update after I get a new cable
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
It could be the adapter, but my most absolute best/stable USB to serial adapter is a giveaway I got like 15 years ago.
Did you check device manager like I asked? We can try some troubleshooting with your current adapter so we can possibly rule that out.
KE0HIN
Berthoud Colorado
BUMMERS PEOPLE I'm open to suggestions I did get a new cable but i still cannot get the program to "see the scanner very strange whatever usb port I plug into the software then sees the port as busy.
KevinC
32D2T/957.282
Super Moderator
What port does the adapter show in device manager?
KE0HIN
Berthoud Colorado
Kevin did all that seems strange my PC has High numbers 9.11.15 for the front usbs I see Andy's only likes Low so I'm going to try the one on the back ofmy computer
Ubbe
Stockholm, Sweden
Just force it to com3 or 4 in the hardware device manager in windows. Windows always tries to use a free com port number that hasn't got any previous drivers installed to it, but it's ok to change a 9 to a 3 even when it's says it's used or busy. But what could happen are that a device that have been using com3 now instead gets a higher number but you can then easily force that back to 3 if you like.
/Ubbe
KE0HIN
Berthoud Colorado
two currently comm port 1 (correct i think) and com port 3 shows as intel active management technology.
KE0HIN
Berthoud Colorado
so when i plug in my usb to serial it said comm 7 changed the point on andy's to comm 7 saved it opened back up went to transmit and it says comm 7 is busy
a417
Change the COM port assignment for the usb-to-serial device to something 1-4.
KE0HIN
Berthoud Colorado
ok Im still getting th port is busy or being used error . but Ive just reached out to the creator of the program so we shall see if he can assist
