780 help needed
KE0HIN
Berthoud Colorado
Im using the old andy's program and when I tery to find radio Im getting the following error coade any help would be great
it says unable to initialize communications to radio
VR REQUEST IS ''
Ubbe
Stockholm, Sweden
If it is the first time you try that program using that computer it can be many different things that could be the problem.
Have it worked before and now suddenly doesn't?
Do you use a USB-to-serial adapter or a real RS232 serial port?
What model of computer it is, a vintage one or very new with Win10?
Have you set the correct serial speed in the 780?
Do you get a different message if you do not connect the cable and also if you have the cable connected but scanner turned off?
/Ubbe
ProScan
Software Provider
Ontario, Calif.
VR REQUEST IS ''
Probably the scanner is not in remote mode. Press the 'E' key for 2 seconds then you should see RMT on the display.
KE0HIN
Berthoud Colorado
its a windows 10 PC I'm usinf a usb to serial cable ive matched speeds so on its a program I loved like 25 years ago ? just trying to update two 780's programs
KE0HIN
Berthoud Colorado
Are you using a null modem cable?
I don't know what that is, but the one I used to use had a box on the dongle from USB to Serial the one I have now does not ,I'm trying ton do this on the cheap they are obviously very old radios.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
You will need either a null modem cable or adapter for whatever your current cable is.
I'm assuming you have a cable between the USB adapter and the 780.
KevinC
32D2T/957.282
Super Moderator
And I don't know if you do or don't have a null modem cable/adapter, just saying you'll need one.
ProScan
Software Provider
Ontario, Calif.
Null modem cables don't work on the earlier scanners. Null modem cables are only needed on the newer scanners where the RS-232 port doubles as a GPS port.
KE0HIN
Berthoud Colorado
you can down load it here
thats where I got it again
KevinC
32D2T/957.282
Super Moderator
Ugh, I forgot how convoluted this program was. While it was cool in 2001, we've progressed so much since then.
Anyway, it works on my Win 11 machine, but personally I'd just get ProScan. Use the 30-day free trial and then if you like it spend the $50.
KE0HIN
Berthoud Colorado
as for the recomended cable would this work?
USB to Serial RS-232 Adapter with LED Indicators, FTDI Chipset, Supports Windows 11/10/8.1/8/7/, Mac OS X 10.6 and Above​
KevinC
32D2T/957.282
Super Moderator
i do but its just a strait usb to serial
Disregard everything I said about null modem, you don't need that.
With your current adapter plugged in go to device manager, then ports and find your adapter, then see what com port it's assigned to.
