996xt learning curve
wesley22
homer glen illinois
Upman, thanks. I reset the scanner to the programmed systems.Following the Uniden Manual instructions under Quick Start,To turn a preloaded system on or off, press SCAN, then press ./no then the two-digit System Quick Key. I cannot get my scanner to scan Ill StarCom21.
rvictor
Milwaukee, WI
The Illinois Starcom system has recently been rebanded. It seems unlikely that the preprogrammed Starcom system would have been brought that recently up to date.
Take a look at the frequencies that are programmed for that system and compare them to what's in the RR database or on the CARMA website.
CARMA Profiles
You may just need to change the frequencies.
Dick
werinshades
Chicago , IL
I'm close to you, just west of Midway Airport. I delete all my pre-program frequencies and add my own. Delete Site and start from scratch.
* StarCom21 Statewide Illinois P25 Trunking System, Statewide, Illinois - Scanner Frequencies
Look at Sites 1-002 and Site 1-015...those should give you the best chance of getting a solid control channel. You will hear District-Chicago, Dist. 15 (Tollways), Dist. 2 (Interstate 55 between County Line Road & Interstate 355) also I 290 in Dupage county, Dist. 5 (I 55 west of I 355, I 57 south of Volmer), just to give you an idea plus a few other things. I broke District-Chicago into 4 groups, North, Middle (I 55 patrol), South, Administrative, and each of the other Districts has their own group. I use ID Scan, but being new may want to use ID Search. You may want to read up on Talkgroup Priority which is very handy monitoring these sites. Have any questions, their's plenty of answers in the Illinois Forum...good luck,
wesley22
homer glen illinois
As you can tell i have along way to go.Your last words,"good luck" I will need lots of it.
Thanks for the help My old scanner is Radio Shack Pro-2006. Now you why i'am
struggling.
rvictor
Milwaukee, WI
I should have mentioned that the CARMA site has the Starcom system already set up in ARC-XT format which you can download into ARC-XT and upload to your scanner or you can import it into FreeScan and upload to the scanner from there.
Dick
