996XT programming help for fleetnet
hawkeye32
Windsor
So i just recently purchased another radio to add to the collection, the 996XT, so far great radio, but i have run into a stump for programming fleetnet. I am using ARCXT programming software, but where it says to enter the low frequency and high frequency i am confused. I know the low freq is for the base, but what is the high freq. I did use the "calculate high freq" option on the software, not sure if it is correct or not so thats why i am asking this question. I have not heard any comms as of yet, thats why i am wondering.
One other quick question i have, is when programming the fleetnet towers, should i use "program motorola trunked system" or just "trunked system" ?
Thanks for any help
chris
VE3JSO
sarnia ont
i am not 100 percent sure but i think it's the same table when you program the pro 106 so the lo chan is 380 and the hi chan is 759 if i am not mistaken
torontokris
Toronto Canada
choose "custom" band plan
bandplan 1
lower 141.0150
input upper 143.9850
offset to 380
+ polarity
spacing to 15.00khz.
bandplan 2.
lower 151.7300
upper 152.5100
offset to 579
+ polarity
bandplan 3.
input lower 154.3200
input upper 156.2250
offset to 623
+ polarity set spacing to 15.00khz.
or enter the lower offset and spacing then do auto upper (should just enter what i entered above in the upper).
I dont remember from my ARC days but try motorola (long as its a VHF motorola system, not 800 not P25 etc).
hawkeye32
Windsor
Ok cool thanks Kris, yes those numbers are the same that the software "auto generated: I appreciate the help :)
ENG911
Mississauga
I was struggling to program 2 996XT's and a 396XT that I got from work. The fleetnet was driving me crazy.
I used FreeScan and imported everything from RR database. ARCxt was giving me grief with my USB to Serial adapter and FreeScan just worked perfect first time. The best part is it's FREE.
ScanNow.org - The Home of FreeSCAN!
Cheers,
Tony
