AB5ID
I think the video is ok to follow now the developer came out with a revised firmware and closed the issue on git hub.Do you know the link to the most current version of software... and maybe foolproof upgrade instructions?
Are you referring to the video in message #47? Mine is not here yet.I think the video is ok to follow now the developer came out with a revised firmware and closed the issue on git hub.
I wish my 3D design skill were better. It would be so cool to have a 3D storage case for this little radio... maybe with a second side to store some cheap earbuds.
How is that little antenna anyways? I've seen it plastered on a lot of Chinese websites like AliExpress. They typically sell for single digits and they seem to have favorable reviews (Unless they're botted).
How well does it receive 40m?
My experience, (your's may very) is that it's a POS, so don't waste your money. What we need is an appropriate connector with a small rod sticking up about an inch so we can use one of those Sangean type shortwave antennas like shown below.
I like your philosophy. I've wasted more on pipe tobacco so I'll get one of these. Thanks for the inspiration.Yes, I bought it for $27USD and have had a great time playing with it. The SSB works pretty well, if you see his follow up video, BFO can be adjusted via the menu. While not the best radio in my arsenal, it works pretty well (I use an indoor amplified loop) with the right antenna. As would be expected, the audio output is weak, but listenable. I have wasted way more $ on lunch and consider this a fun radio to take out and not worry about losing it.
The maker of the ATS Mini has already spun the board to address major issues, including weak audio. The update also includes new firmware and several other hardware tweaks.
For the save amount of money, you might want to take a look at the ATS20+. It uses the same receiver chip as the Mini but is controlled by an Arduino instead of an ESP32. The ATS20+ is about the size of two cigarette packs, has an aluminum chassis, a large speaker, and eight dedicated push buttons. I own both and tend to prefer the ATS20+, which I would recommend over the Mini. That said, I still find myself using both throughout the week.Nice little radio. Don't forget to wear your bifocals hihi.
For they DIY project. ;-)While it's physically larger, the smaller monochrome display on the ATS20+ is the deal breaker for me. As an old man, it kinda sucks that I cannot read the small stuff like I used to. Also, since there are many inexpensive amplified speaker alternatives in this day and age, I'd rather go that route.
It's funny because these radios bounce around on price from $20 - $50. I don't know if there's a tracking tool for AliExpress but it would be useful.I figure it won't be long before the mark-up gets to be too much. 25-30 dollars now, 60-80 dollars sooner or later...
