As many on these forums know, since the release of the SDS100 I've been critical of this radio. My criticisms were based upon what I read,
and from seeing and using, albeit briefly, those owned by friends. It is true that this was not a fair assessment, and deep down, as a radio aficionado / addict I truly wanted this model to be "the one".
So, thanks to Amazon and their Xmas return policy, I decided to play fair and order one for myself. This one is a recent production run with the new, larger battery. Upon receipt it was updated to current firmware and programmed up with my extensive favorites list for the NYC / NJ metro area.
I will make my main point, and then give a bullet list of likes and dislikes:
This radio, in my humble and learned experience is a tale of two radios in one. One radio performs almost flawlessly on the digital trunked systems, P25 Phase 1 and 2 simulcast in my reception area. With a Remtronix antenaa next to my G5, it performs as good as the G5 in decoding those systems. The audio produced from these systems on the SDS100 is quite good.
The other radio is all the rest, and it is horrible. VHF analog comms are basically useless. Uhf comms are slightly better but still pretty bad. VHF and UHF stations utilizing a repeater fair somewhat better, but still very disappointing. There is a horrid, tinny white noise hissing sound that comes through with these transmissions, in addition to weird background data noise coming in as well that I've never heard before and cannot explain. This poor performance continued even when I connected to my topside discone antenna connected to a Stridsberg multicoupler. 20 and 30 year old GRE and Uniden scanners were blowing this thing away. I took the SDS100 in the field today and the results were slightly better in some areas, and not in others. I am at a loss as to why they bothered to include the air band at all. I parked directly across from Teterboro airport in NJ, the nation's busiest private commuter airport and could barely read comms between the tower and aircraft. They were hidden behind a mountain of white noise and hiss. Uniden needs to decide what kind of radios they are going to make moving forward. Solid UHF / 700 / 800 Mhz band digital system radios like the G5, or continue to cram every radio band into one unit. It's not working folks.
A few more quick thoughts.....
Build - solid in the hand. Not as bad as I thought it would be with the big battery. weird shape. Passable.
Display - More crisp but way too much going on. Small lettering not easy to read from a distance. Different colors and customization a nice gimmick but probably not necessary.
Battery life - Even with big battery I ran a few systems, medium traffic with the display going off when not receiving and barely got 7 hours.
This is a computer processor doing a bunch of stuff all at once. This is a work in progress for Uniden. They can do better.
Heat - Yes it gets hot. See above
I very much wanted this radio to be great. I said in the past and maintain my position that this was not ready for prime time. Not for $650.00. There is the potential for an excellent radio lurking inside that thing, but not yet.
If you can live with the problems above, and are happy with what is basically a trunked digital systems receiver that can scan multiple systems, then this is probably for you. As for me, my G5 works just fine and I'll have to say farewell to the SDS100. For now.
