ABOUT FULL encryption
ham2020
I have a question: If I want to do full encryption from the company, what do they give me a program or give them the call to do the full encryption?
If the program can I use it to activate encryption in other devices and an infinite number of devices or how
pb_lonny
VK7AAL
Tasmania
It would be on a per radio basis. How you program it is a whole other matter...
prc117f
Have the system administrator deal with it, they will have the software and technical assistance available from Motorola to make sure it is all, squared away.
Giddyuptd
Here and there
What type of radios you using? Are you overseas?
If you are authorized to make changes by your company it will depend on what type equipment you have.
There is key loaders which some depending on what version you get only do certain types, while there is software based encryption such as arc4 better known as adp, or other variety from vendors in digital end of things.
Mostly a system or administrator or tech under advisement from the admin handles it. But if your the tech or private business go to guy and are authorized then people need to know what type of radios you using, firmware versions, repeaters or simplex etc.
Firebuff66
CT
This guy is on every radio web site asking the same question
ham2020
Thanks for the answer I'm not like some failed people who, if they don't have an answer, make themselves investigators
My question about HYTERA PD785
And about MOTOTRBO DP4600
stantorres
Auburn Hills, MI
If you already have a working digital radio system, operating in digital mode, then:
If your equipment has Encryption built in, then you would have to use Radio Software to turn on that feature and enter an encryption key.
The talkgroups would have to be programmed to operate in Encryped mode, or you could program a button or switch on the radio to toggle the encryption on or off.
If your equipment does not already have encryption built in, you may need to purchase the encryption option and flash the radios.
Encryption is tricky, so if it were me, I would pay my local radio dealer to have a qualified technician make those changes.
ham2020
As an amateur I just want to inquire and I do not want to buy encryption
