ABQ Live Feed Audio
NMPhillieFan
New Mexico
I noticed the audio is fairly poor at times. After rebooting everything, it failed to help. While examining the cables, I noticed I have a broken connector going from the radio to the line-in for the PC. Once this is replaced, the audio should be much better. I also noticed I have a loose connector on the speaker mic, this may take longer to be resolved as it will need to be replaced.
Thank you.
NMPhillieFan
New Mexico
I replaced the in-line adapter today and the audio appears to much better. Please resume normal reporting of issues via the live feed.
Thanks for your patience.
NMPhillieFan
New Mexico
I have had a few people report the feed dropping offline and then reconnecting every few minutes. I believe I have traced this issue back to a bad modem. It's odd that the only thing that suffered from this modem was the audio feed, online games, etc worked fine. But after testing with a new modem for two hours last night, the feed played consistently the entire time. Please let me know if you notice any more "frequent" disconnects.
Thank you.
