AC Adapter for Pro-162?
sffire
SFO area
Will the 9 volt 300 MaH adapter from radio shack work with the Pro-162? or do I need a higher rating? Is it the C plug?
Thank you
DickH
It probably tells you in the owners manual??
Yes, it's on the bottom of page 12.
HOWEVER, many of us on RR recommend using 2 sets of batteries and an external charger. That eliminates any possibility of damage to the scanner from a voltage surge or component failure. It's happened to me and others.
