ACARS = Aircraft Communications Addressing and Reporting System
Any antenna that receives approx 129 through 137 MHz will work. To answer your question in the Aircraft Monitoring Forum, I believe vertical polarization is better.
Choose an antenna for that band that fits well with your situation and you should be fine. A discone would be good, or something dedicated to the band like a J-pole, etc. would be too. I've never listened to it myself but I assume you want omnidirectional since planes are all over the place.
