ACARS DB Entry
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In the database, at least, it is indeed under Nationwide, Aircraft/Airport and under its full name, Aircraft Communications Addressing and Reporting System (ACARS)
Mike
gonzalu
New York, NY
Mike
Thanks Mike... I did link to that entry in the DB ... not sure I understand what you're trying to say?
You mean in Sentinel, I should be able to find it? Can you post a screenshot? I do not have a problem finding it in the DB. My problem is finding in Sentinel to download to radio :)
Ubbe
Stockholm, Sweden
Unidens database only contain frequencies that can be decoded and monitored by the scanner.
If a system have no registred talkgroup it will not be imported to Unidens database or if it is a datasignal that cannot be decoded to voice it will not be imported so those will not be seen in Sentinels database.
It's only 4-5 different ACARS frequencies in use world wide so it's easy to add them manually to a favorite list.
/Ubbe
gonzalu
New York, NY
/Ubbe
Ahh that's right I forgot that... although it is just AM. I use my 536HP for ACARS decoding so was just being lazy and actually curious as to why I didn't see it.
I already have them added manually...
Thanks for your help...
