ACARS on a local network
Scott2553
Dayton, Ohio
I just discovered acars from this forum, and it's awesome! What I'd like to do, is, run acarsd on my desktop pc that has a scanner with an outdoor antenna hooked up to it, and then view the output on my laptop elsewhere in the house. Is this possible?
I'm running XP on both machines, and I'm using a wrt54g wireless router.
Also, I just want to verify, when I put in my map coordinates (I'm in Kettering, Ohio USA) do my west and east coordinates both start with a "-"
Thanks!
-Scott
morfis
Aircraft Communication Addressing and Reporting System
Plenty of websites with with much more information (and the specification via the ARINC website if you are bored).
eg.
http://www.acarsonline.co.uk/
lots of junk on there and it's very out of date (much of the info was culled from two earlier websites about ACARS) but it does have all the basic info you might want.
jlh
Thanks!
-Scott
scott, i've done this in linux with acarsd, i ~assume~ the win version also has the server
capability. not only can you view the output from inside your house, you can view it from anywhere in the world via a web browser. i ran an acarsd server in my basement for a while, was nice to be able to view what it was capturing from work.
yes, your west and east should begin with a hyphen
looks like the win version has server capability too:
http://www.acarsd.org/server_howto.html
Scott2553
Dayton, Ohio
Test Server
O.K., got the server up and running, and I can view it from my local network. However, my server shows up as "offline" on the list of available servers at http://www.acarsd.org/acarsd_servers.html
Not that important, but if someone wouldn't mind checking my server on their end, I'd appreciate it. I'll leave the server up all day today (10/5/06)
dayacars.no-ip.org
Thanks!!!
-Scott
jlh
scott, did you remember to open and redirect the port on your router?
Scott2553
Dayton, Ohio
Ports
Yes. I have both 2202 and 2203 open to the machine that acarsd is running on.
When I got a no-ip account, I couldn't really figure out what to do, but then stumbled on the option to just do a url forward. When I chose that option, I was then able to connect to the server while on the laptop (using clientNG). I'm assuming that is the option I wanted? I'm not finding much info on set ups online from users that are using the "no-ip"/acarsd combination.
Thanks!
-Scott
jlh
can't advise you on no-ip's setup, i use dnsalias.com, but the logic should be the same. as long as the domain you gave to no-ip points to your ip, you should be good on that part.
have you done the deal in acarsd to tell it to publicize your server to the world? haven't run acarsd since the spring, so i can't recall off-hand how to do it, but it should be in the docs.
jlh
scott, also if you are running a software firewall on the server pc, you will want to open the applicable ports through it.
Scott2553
Dayton, Ohio
I'll check that out. I thought Zone Alarm asked me for permision to run acarsd, but I can't remember if it allowed it to run as a server.
Thanks for the tips.....I'll continue to check these things out. I'd love to get this server out to the public.....It's really getting some interesting hits.
Also, I can't believe the range. When a hit comes in, if it doesn't get plotted on my map, I'll pull the flight up on FBO Web. I just got a hit on an American West plane just northwest of Pittsburgh, and I'm in Dayton. Awesome!
Thanks again!
-Scott
Scott2553
Dayton, Ohio
Up and running
Well, all of my router and firewall settings were o.k. The server ended up showing up midway thru the day yesterday, so I'm not sure exactly what happened. It must be running alright outside of my network because I've had 10-11 clients connected ever since.
Thanks for the help!
-Scott
jlh
excellent, scott, it's a great program
W4UVV
Prince George, Virginia--Central Va.
longitude entries
Thanks!
-Scott
Enter a "-" for the east(right) and west(left) longitude entries.
