ACARS
Chris0516
Pittsboro, North Carolina
I would like to monitor ACARS via my scanner(BCD325p2), rather than an SDR. There was a thread: Monitoring ACARS in 2017. It mentions both, an SDR, and a scanner frequency. I tried using an SDR. But it was too much trouble.
invergordon
Palmerston North, New Zealand
It's really quite simple, take the audio output from your scanner via a mono or stereo cable) and plug this into your computer soundcard. Open up your preferred ACARS decoding software and select your audio input from the options (dependent upon your PC/Laptop configuration). And that should be all there is apart from tuning your scanner to an appropriate ACARS frequency.
Chris0516
Searching for ACARS software. Isn't an easy task. All I am finding is unsupported(and out-of-date) freeware or, software that costs a bundle. The cable is the easy part.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Not easy? HAH! You're not looking in the right place, that's all ...
And you might find out about more apps here...
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
One thing about ACARS - if you are using a scanner, leave the squelch open. There's a sync tone at the beginning of each transmission, and many scanners can't open the squelch fast enough. No squelch tone, no decode
Oh by the way - that first 'index' link is for MultiPSK - it's kinda the swiss army knife of decoders - if you can get over the button happy design....
Mike
invergordon
Then perhaps you are not that serious about decoding. If you are then spend some money on PCHFDL (yes it does VHF ACARS as well as HF datalink), The BlackCat decoder or, if you are into other HF/VHF/UHF decoding then the excellent MultiPSK software will see you right. All of these are inexpensive in terms of the development work undertaken. You'll get what you pay for :)
Chris0516
I actually downloaded PC-HFDL.
zytorx
Toledo, Spain.
Dear Chris,
I recommend to use a SDR dongle and raspberry pi (even the cheapest one, I use RPI zero) , you can monitor/receive ACARS from up to 8 frequencies.
I use acarsdec, but I prefer to decode the "modern ACARS" VDL2 this mode contains more information and add also ACARS message. (I'm in Europe, so this mode I think is only working in EU).
For VDL2 I use vdlm2dec both softwares are available on Github.
If you prefer using your scanner, I have the Airnav acars decoder soft.
send me a pm. so I can share it.
Regards.
Chris0516
Dear Chris,
Regards.
I have to go the route of a dongle. I talked to Uniden, today. My UBCD325p2 trunked scanner, cannot use a cable for this. So I bought a dongle: https://www.amazon.com/gp/product/B011HVUEME/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1; I can't find a site where I can download ACARSDec. It was mentioned on plenty of sites. But I couldn't download. I would sure like your help.
zytorx
Toledo, Spain.
I followed this tutorial. ACARS decoder
you can use either a raspberry pi, or any linux computer.
this is a pure command Line program.
you'll need first set up the dongle installing osmocom driver, then the software itself, consider also using vdl2 from same developer.
here the GitHub links.
acarsdec. GitHub - TLeconte/acarsdec: ACARS SDR decoder
vdlm2dec. GitHub - TLeconte/vdlm2dec: vdl mode 2 SDR decoder
take note it is possible to receive ACARS and VDL2 at the same time attaching two dongles and running both programs in the same raspberry pi or linux pc.
Hope this helps.
Regards.
Chris0516
Hope this helps.
Regards.
There is no Windows-based program?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
See message 6 of this thread. It's likely you will be able to find something at that reflector....Mike
Chris0516
I did that. As far as finding the program at either link. It didn't work. The Black Cat ACARS link, supposedly has Windows link. But the Windows link doesn't work. As for the second link to a group. It doesn't have it, either.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Are you a member of groups.io? If not, you should be. I can see it fine; you likely need to get signed up. It's free and I've never had any issues with spam with this system
I also tried the Windows link of the beta version. I got it fine. Maybe your firewall is blocking you
Mike
Chris0516
Mike
When I click on them. nothing happens.
