Is there anyone who has used the WiFi feature in Access Point mode? I am quite familiar with the "infrastructure mode" and use that with my IPAD app quite often. However, I have been unable to find the exact instructions for setting up the "access point mode". Seems easy enough to set the dongle to "access point" in the scanner itself, but how do you actually hook up the RH app on computer or the IPAD app?
In Access Point mode, my scanner says Input SSID BCD536HP_00xxxx (my serial number). Can that be changed? When I press enter, says "Open" or "WPA/WPA2" For the latter, there is a default password "Uniden_Scanner" that I presume can also be changed. Shows the IP address as 192.168.1.1
So I figured would just use that address in RH program or IPAD app, but does not connect. Any advice would be appreciated, or directions to a site with the information. Am going away for a few days, will not have private WiFi connection (public at a hotel), but would like to set the 536HP up in a decent location and use the app. Also, does anyone know the distance that the WiFi dongle for the 536HP is good for. Will that reach, say, 20 or 30 feet. I presume some folks are already using AP mode in their cars.
Thank you.
Thank you.
