SDS100/SDS200: Adding Conventional Frequencies
baybum
Howard County
SDS 100.
I have a simulcast system in my area. I would like to add a couple conventional frequencies. How do I do that?
Using Sentinel and ARC 536.
hiegtx
Dallas, TX
SDS 100.
You would need to add a system for conventional frequencies. It can be in the same scan lisst as your trunked system.
Have you looked at the main database in Sentinel? The channels you want to add might already be in a system in the main database, and you could simply append them to either your existing favorites list, or start a new one. The steps to manually add conventional channels is in the Easier to Read manual.
