Adding multiple frequencies to a channel
ih784
I’d like to monitor all marine frequencies using SDRTrunk. Would each frequency need its own channel. Or, is it possible to add all the frequencies or a range of frequencies to a single channel? Also, how would I go about doing this? Thanks guys!
Enjoi19
Ontario, Canada
You can actually import directly into SDR-Trunk too, to make it easy, since you're a RR premium subscriber. Go under "National Agencies".
ih784
Thank you two! I’ve got them imported I just need to get them in a channel I can record. Checking out the video now.
ih784
So, since they’re national agencies, I’ll have to manually enter them like in the video it seems?
Enjoi19
Ontario, Canada
Shows up and works for me - go to the RadioReference tab and then National Agencies -> Maritime. Find the frequencies you want and hit "Create" and it will auto add into the channels tab for you. You'll still need to build an assign an alias list is all.
ih784
I got that far and created about 58 channels. Is there an easy way to build and assign an alias list?
ih784
Awesome. I was used to importing a system like p25/viper. Didn’t know if this was possible lol.
