ADP Encrpytion garbled traffic
estone4009
Philpot, KY
2 - G4 pagers running on same site both currently on V2.02 firmware (have tested with v1.35 firmware same results) with encryption key installed. One is monitoring non encrypted talk group and traffic is 99% clear and can be understood. Randomly when monitoring an encrypted talk group that is patched with same traffic the traffic is garbled and the pager acts like it cannot keep up with decoding. 5 minutes later it traffic is clear and has no issues. Am I seeing results of what normally happens with encryption and I am chasing an existing issue? It really does seem that with a pager with full signal strength that it struggles to decode the audio at times.
RFI-EMI-GUY
Just for giggles. move the two pagers physically apart, across the room at least.could be that the IF signal from the clear radio is bleeding into the IF of the encrypted radio.
estone4009
Philpot, KY
I will give that a try but it seems to be so random that I can move across room or place touching and maybe 95% of the time it works fine and audio is crystal clear. My gut is this maybe common so trying to decide how far to dig. Trying to open case now with Unication.
Just for the fun of it, check the PPS E7, click on the Zone/Knob where it is programmed, go down to Secure Setting, and make sure it is not checked.
This enable box is checked. If unchecked the pager will not decode any of my encrypted talkgroups as I have verified that in testing.
If checked you will hear the encrypted garble for all encrypted radios, unless you have the appropriate key programmed in using the key loader software.
estone4009
Philpot, KY
The key is loaded and it decodes 95% of the traffic with no issues. It is just not consistent and acts like it struggles to decode traffic at times but clears up on the very next transmission usually.
