ADP on NX5300 DMR repeater problem
otobmark
NC
My NX5300 decodes only digital hell when receiving ADP traffic through mtr3000 repeater (XPR and VP8000). If i go direct between radios it seems to decode fine (not using dual slot simplex). Encode through repeater with NX5300 seems ok. Unencrypted the radio seems fine.
Is there a timing setting somewhere I’m missing? Preamble?
kd4efm
EL98 Florida
Mtr3000 firmware mark? The 8300 and 8400 had the worst issue with adp and basic encryption with old firmware.
otobmark
NC
Not sure on setup—county repeater—can find out I’m sure. All my moto work as well as VP. Have tested AnyTone as well.
I should PM the radio probably. I know in the past with ham repeaters (who knows how they are setup/timed) that the NX was very picky on receive both DMR and P25. I read on this forum that NX1300 series needed to be tuned tighter than spec to work well and maybe the NX5000 need the same.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
In the MTR3000 codeplug, have you checked the enhanced encryption box? I can't remember if it's a box or a drop down menu.
otobmark
NC
Might be awhile before I get hands on the plug. Seeing problems with other radios intermittently—usually just no audio. Not all radios go silent simultaneously so whatever is out of spec must be near margin. Adds weight to your theory about repeater.
kayn1n32008
Sector 001
If it's happening to other radios it's a good possibility that setting is wrong.
Also, the MTR3000 might need an alignment.
