NX5300 cannot talk DMR direct to xpr7550
rescue161
KE4FHH
Hubert, NC
This is bull****. Share your codeplug and I will explain you where you're failed.
This is NOT an option. This is mandatory setting for ANY professional DMR radio. This is part of standard - there is no any wildcard for GID. So, you have to specify one or more if you need to receive Group calls. You MUST specify it.
This is very very very known situation tested many times. Now all looks like you're don't know how to program radio properly. I bet that you have RX group list on channel. I can bet even for XPR radio.
Of course as was stated above, if you're not using the same RID.
You sir are completely wrong.
crazyboy
NJ
Wrong, set to none will receive only the transmit group as was pointed out.
RK3AAG
Russia
I got back from business trip.
So, I was right and wrong at the same time. Old Gen1 Motorola radios with old firmware worked as described = no RX List = No reception at all. But newer firmware radios will receive the same group that is set for TX. So, TX Contact Name allows reception of the same contact (group in case of Group List) automatically.
But! If you set None for TX Contact Name, your XPR will not be able to receive anything. So, if you're not intended to transmit, but want to listen, set RX GL to something you need. And if you want to listen more than 1 group, you MUST set RX GL.
So, I agree with you, that I was partially wrong. Appearence I described valid for old radios with old firmware. And when TX CL set to None.
Anyway, Kenwood NX5000 requires RX Group list. Group set for TX only will not allow radio to receive it. Radio will remain unmuted, but will be able to transmit.
dapaq2
Northwest Indiana
I have seen where two radios having the same subscriber ID will mute each other and for this reason I recommend using a different ID with every radio.
I agree with you that each radio really should have its own seperate ID number, especially when using the individual calling feature, but as info the DMR MARC staff have a different opinion on that, they continue to respond with the statement of "two radios can have the same id". I strongly disagree with them. Anyway, I was told by DMR-MARC STAFF that the maximum number of ID numbers per registrant (Call Sign) is a quantity of (2) two.
BG6WQG
on NX-5300, I cann't find where to set a RX Group.
my NX-5300 doesn't work with Repeater but Talk Around Mode works well.
AD0TY
Indiana
MSS-Dave, We have successfully programmed Kenwood NX-3k and TK-Dx40 radios to work with Harris Momentum radios (which are rebranded Hyteras). We have not tried NX-5k radios.
rescue161
KE4FHH
Hubert, NC
The Kenwood NX5000 series works fine using DMR simplex talking to Motorola XPR radios (6500, 7500 & 5550 radios). Talking through a DMR repeater also works equally well. It has everything to do with programming the radios correctly.
BG6WQG
Thank you, Maybe it's the Repeater's problem. The repeater is built by a MMDVM device.
kd4efm
Florida
Well, I have literally HUNDREDS of Hytera " professional " radios out with ZERO RX group list. There is a check box for RX follows TX contact, I believe it defaults when no RX group specified. I have added Hytera into Motorola conventional DMR repeaters no issue.
Guess I'll have to get the Moto out and see what happens Hytera vs. Moto vs Kenwood.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Hey Dave, You are dealing with a person who knows our jobs better than we do. End of story,
kd4efm
Florida
Honky, I am talking to a friend who has the MMDVM and see if we can't test a few things out with it.
The MMDVM author is in our chat group on NXDN, and said he will take a look at it soon, right now
he has some personal time he is taking for the end of the year.
Keep in touch with me, I will let you know when we start this project and work on the Open Voice and
a few other things we are going to try with the Kenwood on the MMDVM.
Evans
BG6WQG
Evans
Thanks. G4KLX (MMDVM author) replied on github said he tested no problem.
BG6WQG
Check out the problem is the frequency of interference, When i move to a new place, the problem disappear. Thank you.
N4KVE
PALM BEACH, FLORIDA
All my radios have the same ID number, & DO talk to each other. There is a setting in the radio that prevents this, but I forget what it is called. I go to the mall with my wife, & talk simplex with both radios having the same ID number. Also NONE of my radios have RX groups, because around here there is only 1 TG on a TS.
