ADSB and B52H ICAO hex ids
gary123
Short answer, you can't. However you can limit the ICAO IDs received by entering AE58.. which will return anything starting with those first 4 characters.
Thank you. That will work well enough most of the B52 are between AE56 and AE59. I will experiment on using AE56..||AE57..||AE58.. Ill report back the results.
gary123
As promised here is my report. You can set multiple wild card ICAO ranges. I have tested using this. AE56..|AE58.. I chose these two values in order to hopefully get the ICAO for 60-0042.
gary123
Here is the current B52 ICAO list for 2023. All the entries in pink are verified as to the ICAO and the tail number. Anyone wishing to use or provide the list to ADSB/Flight24 or any other flight tracker may do so.
The file is a Microsoft .xml and can be opened with office /office365 or any number of free online programs.
  • B52 2023.zip
dziban303
Hey there,
I'm trying to update the BUFFs in the database we use for Planefence. Have you got an updated copy of this list? If so can you send it to me somewhere other than the forum, which won't let me download attachments?
gary123
Yes I will be happy to send you the updated current list. DM me with your email ill send you the file in any format you would like. I daily check several sites to update the list. I would be happy to add yours to my daily checks.
Everyone: This information can be added to any flight tracking sites. It is as accurate as possible. The pink lines in the document are aircraft where the ADSB ID has been both tracked and the aircraft photoed at the same time. As always I can be DMed with any updates or aircraft confirmations.
  • B52 2024.zip
dziban303
Hey mate, thank you! I apparently don't have permissions to DM anyone, probably because I never post. If you could email me the doc at dzibanorama (at) gmail.com that would be hugely appreciated. There are so many sources online and many of them disagree with each other on tails et cetera. I think your list is the most authoritative and want to get them all in our database!
Cheers
