Advice dsd+ audio input / outputs ?
Jono400
Hi guys hopefully correct forum this time !!
okay using windows 10 pc along with sdr# and free dsd+. Problem is although any dmr signal data is showing up within the dsd+ screen the actual decoded audio is not comming thru . Could not work it out as honestly thought I must have the correct input / output settings set for it to actually show up the DMR data but guess the actual setting I have for any decoded audio is wrong. Say that as just happened to notice earlier today when looking within my audio settings that when and only when there was actual decoded audio the little bar graph for the default communications device responds as per picture.
anyone be so kind as to look at the attached settings and advise what’s wrong and how to fix ?
thanks guys. John
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Show more of the DOS window with the DMR stuff in it. It might just be DMR data, and thus no voice. You need to show your main DSDPlus screen and the DOS command prompt screen. And make sure you have Filter Audio unchecked.
Jono400
Hi yes sorry confirmed filter audio unticked and 100% DMR audio as was listening to it in my dmr handie next to the sdr rsp1.
Jono400
A few screenshots.anything obv in way of audio settings ?
Jono400
All working guys !! Just happened to make the communications device default and sound came thru 100 %
appreciate all your kind help and suggestions.
John
