After DMR
amickey1979
Easton, MD
After I updated my G5 to receive DMR the pager is saying that I am out of range on previously programmed systems. I am monitoring MD FiRST. I did not change anything else and have not really fooled with the DMR.
N6ML
Hmmm. No such problem here. Is it out of range all of the time, or just dropping out sometimes? Did you load a new profile, or just run the DMR FunctionUpdater? The latter is supposed to only change the model number - everything that worked before should be unchanged (as I understand it).
w9zro
yep out of range on all just followed the PDF instructions
amickey1979
Easton, MD
Just ran the updater. I did not change anything else. I reloaded the non-DMR profile and it is working.
N6ML
This seems self-contradictory. If you have a non-DMR profile, it suggests you have a (new) DMR profile too? Is it possible that you selected the wrong model when you created your DMR profile?
w9zro
welp I found my problem i loaded the wrong "code plug" from my list its all good now I AM A MORON !!!!!
N6ML
I'm sure you're the first to make a mistake like that :D Glad it was an easy fix.
amickey1979
Easton, MD
I will check out as soon as I get home. I will post a report.
w9zro
yeah the Panic set in and i walked away ... ALWAYS BACK UP BEFORE YOU PLAY!!!!!!!!
amickey1979
Easton, MD
I made sure that I had the correct model. The pager loads the codeplug but keeps reading "Out of Range". When I scoll the pager down my site ID and WACN are missing.
