Problems programming ICOM F4161DS?
30319
Has anyone else experienced problems programming an ICOM F4161DS? I was able to program it once and now did does not recognize the com port. Does the F4161 play well with Windows 11 Pro because that is what I am using. This is my first ICOM purchase and I really like it. Any wisdom or help you can provide would be appreciated. Thanks!
ramal121
Lots and lots of watts
Calif Whine Country
Are you using an OEM Icom cable?
The one I had for many moons was the OPC-1122U-B. I received a new cable, an OPC-2344-1. I continued to use the older cable until one day it quit on me. The new cable works fine. I don't have an answer but maybe some behind the scenes shenanigans with the cable driver? Using Windows 11.
30319
Well miracles of miracles it started working late today! Thank you for all the great suggestions!
Can someone tell me how to change very narrow and narrow in the software regarding NXDN for this radio please?
30319
So the ICOM F4161DS will only support very narrow (4800) and not narrow (9600)?
Some of the Icom iDAS radios were 6.25KHz NXDN "Very Narrow" only. I believe that is one of them.
I haven't touched Icom LMR gear in quite a while, so maybe someone with more familiarity in the Icom iDAS product line can confirm.
16b
Central Ohio
I had a 4161DS a while back and it only did 6.25 (“very narrow” in Kenwood parlance). I have heard tell that some newer Icom iDAS radios will do 12.5 (“narrow”) as well, but I don’t believe any of the early iDAS radios did.
Somewhat tangential, but I recall on at least one occasion Icom having a separate booth at Hamvention for their commercial products (this was back in the Hara days). They had some of the earlier iDAS radios there one year and they were pushing the spectral efficiency aspect of 6.25 really hard. I suspect the true reason for doing 6.25 exclusively was to make the engineering easier/cheaper, but they were really turning it into a selling point.
