What is the best scanner, base or handheld to monitor air band traffic?
I think the BCT15 and BCT15X are very under appreciated for civilian air and milair monitoring.Base BCT15X.
I use it's older brother BCT15 among my many scanners for Mil Air.
military aircraft operate voice in AM mode between 138-143.975 MHz
Thanks for the infoBase BCT15X.
From the frequency response curve for that particular FM block filter I would be concerned about reception from 118 - 137 Mhz. The 3 dB skirt is at 76 and 122 Mhz .The upper end of the notch is 150 Mhz with 122.185 Mhz at marker 4 about -3dB, and below 122.185 then down to 108 Mhz at -50 dB. Its good for frequencies at 150 Mhz and up, but looks to kill a third of the civilian aircraft band voice frequencies. I was curious about it because inexpensive filters will not have a narrow notch, and unlike other FM block filters on Amazon this one shows the frequency response. Others listed don't provide the response but they are probably similar. As an FM block filter it appears to be good, but the civilian aircraft band is too close to FM broadcast for cheap filters.BC15X and the handheld version if you can find one, the 346XT. They're the analog cousins of the 996XT/396XT and are the best I have for airband. Don't forget a good aviation band antenna, and if you live near any FM station transmitters a good FM block filter will definitely help reception. I have a couple of these RTL-SDR FM block filters and they made a noticeable difference in reception on air band, plus are reasonably priced-
Broadcast FM Block Filter (88-108 MHz Block) by RTL-SDR Blog Amazon.com
We have measured most of the filters out there in this thread: FM bandstop filter comparisonOthers listed don't provide the response but they are probably similar.
Nice! Thanks. The HPN-30118 and ZBSF-95+ should be very usable with airband. Much more narrow notch.
All scientific testing aside, my real world use for it says it works fine. I use it primarily for 118-136 and noticed a huge improvement using it versus going without it. YMMV.From the frequency response curve for that particular FM block filter I would be concerned about reception from 118 - 137 Mhz. The 3 dB skirt is at 76 and 122 Mhz .The upper end of the notch is 150 Mhz with 122.185 Mhz at marker 4 about -3dB, and below 122.185 then down to 108 Mhz at -50 dB. Its good for frequencies at 150 Mhz and up, but looks to kill a third of the civilian aircraft band voice frequencies. I was curious about it because inexpensive filters will not have a narrow notch, and unlike other FM block filters on Amazon this one shows the frequency response. Others listed don't provide the response but they are probably similar. As an FM block filter it appears to be good, but the civilian aircraft band is too close to FM broadcast for cheap filters.
It is likely the SDR dongle was interfered with so badly that it benefitted from the filter, but the sensitivity will still be way down at 118 to 122 compared to a non SDR scanner. I dont use any SDR dongle for analog because they get so messed up from images and intermod. They work ok for digital. They are hugely frustrating with analog. I wouldnt recommend that filter for use with a non SDR scanner. It might help the SDS100/200, but I sort of doubt it.All scientific testing aside, my real world use for it says it works fine. I use it primarily for 118-136 and noticed a huge improvement using it versus going without it. YMMV.
What SDR dongle? I'm using it them on my 15X and 346XT. They've worked fine for me, even around the lower end 118-122. I was just listening to it earlier this evening. Cleans up all of the static I get without it.It is likely the SDR dongle was interfered with so badly that it benefitted from the filter, but the sensitivity will still be way down at 118 to 122 compared to a non SDR scanner. I dont use any SDR dongle for analog because they get so messed up from images and intermod. They work ok for digital. They are hugely frustrating with analog. I wouldnt recommend that filter for use with a non SDR scanner. It might help the SDS100/200, but I sort of doubt it.
But long before that is happening, that you easily can hear, are that a receiver looses sensitivity gradually with a signal gradually getting stronger anywhere in the frequency band that the filters will pass to its electronic circuits in the receiver, a desense. When I check desense in a small super sensitive 0,15uV Icom R2 scanner it desense heavily from just a moderate signal strength but a 0,6uV sensitive Regency Pro-2006 doesn't desense at all even when exposed to a huge signal level, making it receive much better than the Icom unless there are no other interfering signals in the frequency band.and never once had an intermod or image issue of any kind.
