Air evac
bigpapaw
Connersville In
I'm looking for the freqs for air evac . We have a evac base in rushville in. I know when the come to connerfsville they go off 155.160 i think. But does anyone no other freqs for them.
Viper43
Thats the main frequency for them. However I haven't heard AirEvac in Rushville in a long time, only LifeLine and StatFlight in the past few months.
Another place to find them is on the statewide system SAFET, but then you need to know pretty much which unit they are as they are all ROMEO ##. Lutheran Air tends to use their name and ROMEO##. All comms on SAFET are on TGID 5040
W9NES
Indianapolis,Indiana
Viper 43, You are Correct 100% If there are any listeners in the Connersville area that know what frequency they use besides 155.160 along with Safe-t talkgroup 5040 could they please post them here on the fourm.-Rushville Then the infomation could be updated in the Indiana Database for AirEvac Operations in the Rushville coverage area they cover from that part of the state.
W9NES
155.340 is Statewide for IHERN for all Ambulance and Medical Helicopters en route to hospitals for patient infomation, BP,etc.
spooney
Indiana
Air Evac Lifeteam at Evansville Home Show
See the Air Evac Helicopter on display at Roberts Stadium April 1,2,& 3, 2011.
Viper43
And this has to do with OP's ? how? I don't think Roberts Stadium has anything to do with AirEvac in Rushville In.
As to the OP, I'm thinking that AirEvac got booted out of Rushville not long after the chopper crashed there due to issues with the companies maintenance. And since then the only AirEvac I have heard even close to there was out of Ohio and that was because the others here were all busy.Ihave been checking under other AirEvac licences and their FRN and there is nothing I have found yet for AirEvac in Rushville. There are 4 pages of licenses for AirEvac under their FRN and it will take a while to go through all of them.
You may get better results with the Lifeline Columbus channel: 151.9850 tone:173.8 and the normal LifeFlight frequency.
Also, if a DB admin sees this thread they should delete the listing for AirEvac from Vanderburgh Co as that license has been terminated so it should be removed as it's no longer active.
kb9sxk
Southern Indiana
It sure is active.
W9NES
Thanks Viper 43 for your post and update on AirEvac.If ANYONE in the Evansville area can find the ACTIVE freq for AirEvac could you please post it so it can be updated in the DataBase.
nd5y
Wichita Falls, TX
Try 151.505 and 158.400. They use those at several locations in Texas with no license. They might do the same thing in other areas.
W9NES
KB9SXK, Please post the Acive frequency you are hearing radio traffic on so that the Database can be updated. Thank You
spooney
Indiana
Air Evac Lifeteam Evansville
Adam is correct they are based at Deaconess Hospital 600 Mary St, Evansville. The database does need to be updated with the "New" license number WQGH464 which was activated in 2007 and good till 2017. I will submit it to the Database Administrators right now.
Viper43
The FCC shows it is TERMINATED....with nothing else showing so .........
W9NES
Again the question that I asked has not been answered. Spooney or KB9SXK can you post the correct frequency that you are hearing Radio Traffic on???? Then the infomation can be updated in the RR data base for AirEvac.Thank You.
