Aircraft
SA_tx_88116
Rather listen than stream
Cibolo, Texas
I would love to know if there is any possible way to program an aircraft control tower into my RadioShack pro 197IMG_0172.png
Sydney Australia
Yes but can UHF and VFH and AM frequencies be programmed
Yes it can.
Your scanner can receive VHF, UHF, AM, FM and FMW which is used for FM broadcasting stations currently designated 87.9 to 107.9 MHz.
Aircraft frequencies range from 118-137MHz in AM mode and the range is called VHF. The channel spacing is 25KHz or 8.33KHz ?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Also keep in mind you'll only be able to receive tower to aircraft reliably from no more than a few miles away from the airport. From further away you'll only hear aircraft to tower and not the other way around
dave3825
Suffolk County NY
Like I said, anything and everything for that scanner is in the link provided. These are all defaults in your scanner unless they were changed.
108-136.9916 Civil air VHF
225-379.99375 Military air UHF
