N
N_Jay
Guest
When ever I have used a GPS on a plane (at cruising altitude) it has always been dead on (e.g. 35,000 ft)
adkad said:In another thread on this same issue someone mentioned a type of receiver that can pick up atc communications and is legal, because of the way it works, but I can't remember the product. Can't find it on google either, so if anyone remembers it might help to post it here. Thanks, Adkad
toydriver_det said:Ramsy sells a radio that they CLAIM is legal to use on a plane but I doubt it really is. I think it is Delta that lets you listen to ATC on one of their music channels.
Newark777 said:That Ramsey radio would still be not allowed on most flights. Keep in mind that most rules state "AM/FM receivers or radios," and it really makes no difference whether the maker claims no interference. The fact is, the FAA can't test every device like that, so they just do not allow any whatsoever.
As for UA channel 9, it is up to the pilot whether or not he/she wants to enable it, and some passengers are disappointed to learn the pilot hasn't activated it for their flight.
N_Jay said:I have not been on any United flights (about 30 or so) this year where it was not on.
ind224 said:I'd have to agree with most on this one.
1) Listen via the entertainment center if possible.
2) Asking the Captain when boarding may get an OK especially if you are a pilot but again even an OK will not get you very good reception.
As far as the transmitting, an amateur licensee has the right to operate provided the Captain approves it. I personally listened to a scheduled contact on 14.147 USB; the Captain was the operator. An Air Canada Airbus,aeronautical mobile. Being able to use the planes HF radio is a big plus;outside antenna and probably at least 100w PEP.![]()
N_Jay said:One quick reminder; As long as you are on a US commercial flight, the pilot DOES NOT have the right to allow you IF the air carrier has already disallowed it. (Canadian laws may be different)
Laptops can be questionable already, but they are allowed if wireless is turned off. Scanners and other radios are not permitted because they have oscillators which emit on frequencies that can interfere with aircraft communications and navigation.carmelof said:Hello,Airlines should allow People taking Scanners on board aircraft because anyone can take a laptop or a mobile phone in which anyone off these devices can cause interference with instruments.
Regards Lino (Melbourne Australia)
ind224 said:This is why the airlines had to come up with a responsible cell phone policy.
ind224 said:While there is the possibility of some interference, science and common sense should be able to find a balance. I have long said my scanner hobby has never killed anyone but if the possiblity exists it needs to be scrutinized.
If we have interference, it should be proven and steps taken to fix the problem.
If better sheilding is required, make those devices that are not transmitters but just spurious generators pass better FCC tolerances.
