Are the two TGID's known? If so, they should be in the database so that people can at least find them. And of course if 460.325 is no longer being used, the conventional listing needs to be modified.They utilize two encrypted talkgroups on the P25 system.
Used to hear them on a portable scanner I am about 7 miles awayIt's likely a low power setup at the jail. Are you within a few miles of the facility? Did you ever hear them?
It's also possible they have moved to the County trunked system.
Many thanksAre the two TGID's known? If so, they should be in the database so that people can at least find them. And of course if 460.325 is no longer being used, the conventional listing needs to be modified.
Mobile use of a scanner is illegal in NY State. County Sheriffs patrol the area. A better approach may be to use a frequency counter to pick up nearby active radio frequencies.if you got caught, you are already inside...
i am sure they don't allow scanners in there, but it would be a good opportunity to listen.
think positive !
