BCD436HP/BCD536HP: Alerts
NWI_Scanner_Guy
Dyer, IN
So, I have a new 346HP arriving later on today and I have a question about the alert function(s).
On my WS1040, I have it set up to alert me with a beep and a flashing LED when it receives a wildcard TG. Since the 436HP uses ID SCAN / ID SEARCH to find TGs not in a Favorites List, is there any way to set up an alert when a TG not present in an FL is picked up? I've been reading thru the easier-to-read manual, but didn't run across anything that sounds like what I'd like to do. Has anyone come up with a method to do this that's not covered in any manual?
Thanks in advance for any info, tips, hints and/or suggestions provided.
hightime
Menominee County Michigan
No, at least not that I have found. I do use the computer aided scanning features of ProScan. I set the scanner on ID Search and
ProScan's history grid to look for new Tg's, and then setting alerts to ID them.
NWI_Scanner_Guy
Dyer, IN
Alerts only work on programmed channels, unfortunately.
That's what I was afraid of. Bummer :(
I'll give hightime's suggestion of Proscan a try and see what it logs.
Thanks for the replies. I appreciate them!!
