Alpha Tag Delay
Ret_Batt_Chief
Windsor,ca
The alpha channel tags from my stream work fine in Broadcastify pro, but in some 3rd party apps like Scanner Radio, there is a several second delay on alpha tags displaying. Often times a different channel or talk group is transmitting when the previous transmissions alpha tag is just beginning to display. Any fix for this?
rcool101
Eastern Ohio
What program are you using to stream? I use Radio Feed 6.1 by ProScan (free). I listen to my feed on Scanner Radio Pro. My TGs show up in a split second on my phone.
madrabbitt
NM
I'm going to add to this instead of creating a second post.
While using the official pro app on an iphone, monitoring my own feed, the tags seem to be delayed as well.
I dont recall this being an issue in the past, but i noticed it after making some recent changes to the feed and the computer that supplies the audio
