nexus, /715199924 is the mount assigned to me by RR, I did have the ICECAST_USERNAME set to admin and I had tried upper and lower case for 73cuda. I had already done the port forwarding on 80 and 8000 in my router. Also, when I used ICECAST_URI=/admin/metadata.xsl?mount=/715199924&mode=updinfo&song=%s, TGM would not get the "OK" rcvd back.
So here's what I just did, since I switched from oddcast to Simplecast (as oddcast was not sending the tags to RR either), in monitor.cfg I commented out the Icecast stuff and uncommented the Simplecast section, added my PC's IP and port number and holy cow, I'm now getting alpha tags being sent with my RR audio feed !!! FINALLY ! The only thing I'm not 100% happy with is that the tags now scroll in Winamp rather than static, but at least they are there now.
I highly recommend Simplecast, very easy to use and I think the audio is clearer too. Speaking of the audio, I am running out of the LINE out on the BC895XLT to LINE IN on my sound card. I have the line in volume all the way up on the PC and the volume on the BC895XLT 3/4 full. I'll try some other options such as speaker out or MIC in and see if I can get louder and keep it clean. I also have an 1:1 isolation transformer inline.
Now if I can get someone in Marion county to feed the MCSO digital to RR.
Thank you all for all your time and help, I really appreciate it,
Steve
BTW: My feed may go down for a little while sometime soon as I'll be switching to a dedicated PC. And, you may notice some static once in a while, this is due to when we have really heavy storms here my signal drops, I think due to all the leaves getting wet (?) I'll see if I can add that to my feed info.
