"Alternatives"
TFrank615
Springfield, Ohio
What does the checkbox that enables or disables Alternatives do? Under a 7/800 P25 Talkgroup if you set it to Selective Call, down at the bottom under revert to whichever channel then when you select Sub Group Options you have the tones you can select and at the top it says "Alternatives" Just curious as to what this actually does. Thanks!
CFP387
Rowan County, NC
If the Alternatives check box is checked, the unit will always allow radio traffic to pass through for you to hear it. If the box is unchecked, the only radio traffic you'll hear is when the pager is opened up after it alerts. You can set the pager to revert back to a "selective call" mode again or stay open after it activates.
