OkieBoyKJ5JFG
- Joined
- May 16, 2022
- Messages
- 298
- Reaction score
- 218
Yes, I did a search of this site as well as YouTube and the internet at large. Now I'm more confused than before.
I recently had a new audio system and backup camera installed in my 2009 Ram 1500 pickup truck. Yesterday I was told by a very experienced ham that I have a little "alternator noise" with transmission. He described it as "a whine and a little static" not loud and not interfering with his ability to understand my signal, but definitely present. Before the new sound system, nobody ever mentioned it, which doesn't prove it wasn't there before, but I'm guessing it wasn't. Possibly it's so minor that nobody bothered to mention it before, but the timing right after the new sound system makes me suspect it's related to that. The truck's engine is a 5.7 liter hemi and as far as I know, the alternator is original. The radio is a TYT TH-9800 with power wired directly to the battery positive and negative posts and properly fused. The positive lead has a relay to kill power when the ignition is turned off, also properly fused. The antenna is a Comet SBB15 6m/2m/70cm tri-band fed by 10' of RG8x coax. I don't know how much of this matters, but I figured I'd just provide it all up front.
As I said, I've done some searches. Most of the results were about suppressing alternator noise in your audio system, which isn't a problem here. Some of them mentioned placing the suppression device as close as possible to the affected device, others recommended placing it at the alternator. Do I want a ferrite bead(s), an alternator noise suppression device, or both? Exactly where should I place the device(s)? I'm a new ham, so a lot of this is new to me. I don't want to dismantle the dash to chase down a ground loop, and if there's some easy fix, I don't want to take it back to the installer to chase it down and be without my truck for a few days. I only got my amateur license in December, so a lot of this is new to me. If the solution seems obvious to you, remember that you were once a noob too.
A little education goes a long way. Thanks in advance.
