friedthat
howdee folks,
i need to find out if i can use an old tv amplifier to boost the signal for my scanner.
here are the specs: UHF/VHF/FM distribution amplifier, 2 outputs, 75 OHM Coax with gain control and switchable FM trap.
Bandwidth: VHF 50-400MHz UHF 470-890MHz
Gain : 25 DB 23DB
Response flatness +/- 2 DB
Max Output : 40 dBmV
Noise figure : 4 DB 7 DB
impedance: Input 75 OHM -1
Output 75 OHM -2
FM Trap attenuation:
(switchable) -20 dB 88-108 MHz
now i find it works well with some of trunked Motorola BMR Fleetnet 140- 145 MHz range.
However when i tried to use it on an EDACS Standard system (863MHz) i can see the signal on the scanner go from 0-1 bar to 3-4 bars BUT i do not hear anything and it does not stop on the control channel.. i don't understand . so after given the following info can some one help me out.
Gain : 25 DB 23DB
Output 75 OHM -2
