Even if UHF is all you think you need, this is not a good option.
You asked a question, you received a good solution, but chose not to listen.
I would not recommend or use this for many reasons. My guess is you do not understand things like Noise Figure, Total Gain and Intermod performance. We do not expect you to fully understand these things, that's why we are here to offer our experience and expertise.
If you want to use this, your choice, but the performance will not be very good.
Sorry I have to be blunt and call it as I see it.
The nominal Noise Figure of this Amplifier you are considering is around 7 dB give or take depending on the frequency and depending on how the part is integrated into the circuit board, the Noise Figure will likely just increase. This is a HORRIBLE Noise Figure, this is NOT a first state amplifier, it will likely be far worse than your set up without an Amplifier.
Here is the link for the Amplifier chip that is used -
http://www.analog.com/media/en/technical-documentation/data-sheets/AD8367.pdf
