- Joined
- Aug 10, 2016
- Messages
- 6
Title is my disclaimer. I'm not new to the hobby, but I've had good luck squeaking by with minimal knowledge until I moved. I'm new to the area and I'm having trouble wrapping my head around this problem.
I previously lived in the Boston area and purchased two "MVP" scanners (Minimum Viable P25), the BCD996P2 and the BCD325P2 because money. They both worked fine for the very local monitoring I was looking for.
Now I'm trying to monitor the Ontario North Simulcast. I'm a mile northwest from the tower in the center of Canandaigua and put a 700-900mhz ducky on the base scanner, but I get nothing. Occasionally I get a hit with no audio and the RSSI value is in the 3 or 4 hundreds (I don't know how to translate that to dbi). For comparison a weak FM station comes in above the 500's, so I assume weak signal, maybe that's my first bad assumption.
When I grab my portable with said ducky and ride my bike towards the tower with broadcastify in one ear (thanks whoever you are) and the scanner in the other, I start receiving reliably about a half mile away.
Now I've heard that minimum viable scanners such as mine can struggle with Simulcast, but the examples I find online seem to suffer from distorted audio, not weak-signal-no-audio.
I'm willing to start the campaign of convincing my wife to buy better equipment if I know it will work, but concluding on whether I have a signal problem or a simulcast problem is tough. I thought it was reasonable that an indoor antenna can catch the tower just down the street.
Do you have any pointers on confirming the type of problem I have and if antenna's or new equipment are the remedy?
