Analog display format
bobruzzo
W1AV
Cranston, Rhode Island
I programmed about 11 analog freqs just for the heck of it and the reception is good. But why does "CSQ" appear in the display instead of the actual name of the organization? I wonder if you can tweak it in the PPS?
K9KLC
Southwest, IL
Unless someone knows something I don't, the bottom "Landing on" is what you're going to see, similar to the Alpha tags we use when programming most other radios on analog. There is no way for it to decipher otherwise. (again unless someone knows something I don't). Again I think you're blurring the digital/analog lines.
K9KLC
Southwest, IL
This is how my weather band zone looks when it locks on a programmed frequency (channel).
OK I am still getting used to the G5 and don't know all the little quirks.
Analog radios do not use/broadcast radio IDs or Talkgroups, so there is nothing to show in the To and Fm area of the display, hence it shows CSQ.
