Another antenna question
Ubbe
Stockholm, Sweden
The ends of a halfwave are high impedance at several thousands of ohms and will need some sort of adaption to a lower ohm coax.
/Ubbe
popnokick
Northeast PA
The Laird B1442N has a base loading coil and is designed to be used with 50 ohm coax, with a tunable (cutting chart) bandwidth of 5 mHz between 144 and 174 mHz. I don't understand the reply from Ubbe regarding needing "adaptation to a lower ohm coax".
alabamarailfan
lu81fitter,
Use the cutting chart that comes with the antenna. It will take in to account the base loading and other features to get you centered about 155 MHz.
John D. Peterson/ W4JDP
lu81fitter
Marshall County, Illinois
The base load is required to match it to a 50Ω radio/coax.
That's what I was looking for. Thank you.
lu81fitter,
I did not purchase that antenna. I was just using it as a reference.
Ubbe
Stockholm, Sweden
I often try to explain why and the reasons behind it instead of a simply yes or no. Maybe the person will learn something and improve his knowlededge and the next time he find hemself in a similar situation he hopefully can figure out the answer himself and have a better understanding of the whole picture. Of course there will always be people who couldn't care less and only wants to be told what to do and will never understand how things work. There are usually several people answering an OPs questions and he can then choose which answer will best match his skill set.
/Ubbe
