fredg
I hope I don't get in trouble with the mods for starting a new thread but I really need to get an opinion on this!
OK, in my other threads I wrote about how I am grounding my outside antenna. I sunk a 8' ground rod and used 6 awg solid copper wire to connect the ground rod to my mast.
My next project it to bond this rod to my main house ground. I searched and searched and cannot find a ground rod for the house.
I did figure something out and thus my question....
I have a tiny basement that only contains my furnace and and water heater. There is a 240 breaker panel also in the basement. This is for the air conditioner and dryer.
I opened up the panel to try and see if there were any clues as to a ground.
It has a heavy bare twisted wire that I figured is the ground for this panel. The wire comes out of the box and disappears to an area that is un-accessible.
I remember reading that a lot of old houses used water pipes for grounds.
So I took my VOM and checked between the ground wire in the 240 panel and a water pipe running through the basement.... sure enough they are connected!!!
So I have identified my ground. As a side note like I said in my other post all but about 2 outlets in my house are not grounded even though they have 3 prong outlets (bad I know).
So the obvious question is can I bond my new ground rod to the water pipe in the basement or to the ground connection in the 240 panel?
EDIT TO ADD: I ran a temporary wire from the water spigot on the side of my house (and about 15 feet from my ground rod) to the 240 panel ground in my basement, used my VOM to check.... sure enough they are connected. Seems like I should be able to connect my ground rod to the spigot. Heck this might give the overall house a better ground. Opinions?
