Another MCS2000 question
RT145
I have it programmed with only 1 priority in the scan list. That channel has a PL programmed into it, however whenever anyone on that same frequency talks, even if its on a different PL it trips the priority. All you hear is the beep and it switches to that channel, and the yellow monitor light is on so you know someone is talking on that frequency. Is this something in the programming that I can change?
WX9EMS
Under the Cheddar Curtain
A little more information would be beneficial. What are you current settings in CPS? Maybe offer to share your codeplug. I do not use priority. The break in the busy channel annoys me when it looks back at the priority channel every x seconds.
RKG
Boston, MA
You need to invoke an option known variously as "Channel Marking" or something like that.
What it does is, if the radio detects valid freq but invalid tone on a priority channel, it marks the channel as busy with co-channel, and temporarily deletes it from the scan list except for a period check to see if the valid freq has dropped, in which case the channel is restored to the scan list.
For the MCS2000, I believe you'll find this option in Scan - Scan Configuration - Conventional.
RT145
Okay thanks I'll look for that. Do you know how to do it on the CDM1250 as well? I'm having a similar issue w/ that but I can't find anything about channel marking in the CPS.
ramal121
Lots and lots of watts
Calif Whine Country
For a priority channel check, the radio has to switch channels, do a quick check and get back to the original channel. This creates a dropout at intervals. To check for carrier only is fairly quick. To stop and check for carrier and also decode PL requires much more time and the dropout time would become objectionable. Most manufactures remove PL for priority checks as a simple solution and sometimes that's all you get.
But there are some novel work-arounds if the radio supports them. As RKG mentioned for the MCS2000 you can invoke channel marking. For a CDM1250 you'd set your PL Scan Type as Priority and Non-Priority Channel.
RKG
Boston, MA
As as an additional note, if you employ priority on a working radio, Priority 1 should always be set for "Selected Channel." Otherwise, it can be hard to maintain a conversation back-and-forth if the a priority set for some other fixed channel keeps knocking off the person you are trying to converse with.
